Activity Forums Maxon Cinema 4D Override set driven keys
  • Override set driven keys
    Posted by Dean Chapman on July 26, 2012 at 10:35 pm
    Is there a way to override set driven keys?
    I have Joint A’s rotation attribute driving Joint B’s rotation attribute.
    It’s good, but i’d like the option to manually rotate Joint B throughout the animation.
    Is there a way to alternate between the driver, and manually rotating?
    Dean
    Adam Trachtenberg replied 14 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 28, 2012 at 6:54 pm
    What I would do is, instead of using Xpresso to drive the rotation, use a constraint tag. Then you can keyframe the influence of the constraint.
