Activity Forums VEGAS Pro override DVDA warnings?
  • override DVDA warnings?
    Posted by Mary Waitrovich on May 17, 2006 at 9:15 pm
    In creating subtitles in DVDA, is there any way to override the warnings about the placement and complexity of the subtitles?
    Mary Waitrovich
    UW-Madison
    Mary Waitrovich replied 20 years, 3 months ago 2 Members · 4 Replies
  • Edward Troxel
    May 17, 2006 at 9:29 pm
    Can’t you just ignore them? Or are you wanting the warnings to not appear?
    Edward Troxel
    JETDV Scripts
  • Mary Waitrovich
    May 18, 2006 at 11:10 am
    You can’t just ignore them because the finish button is greyed out until you adjust them to the “dvd specification.” I will be showing this on a computer through a projector so the safe area doesn’t matter and I’d rather have the subtitles lower on the screen.
  • Edward Troxel
    May 18, 2006 at 1:24 pm
    Ok, I just started a new DVD project, added a video clip, went into the video clip, added a sub-title track, added a single sub-title event to that track, and moved the sub-title to the lower left-hand corner. I then clicked on Make DVD, told it to prepare, and was able to go through all the screens with no warnings at all about the sub-title placement. This test was run on DVD A 3.0b (that machine hasn’t yet been updated to 3.0c).
    I then moved the subtitle so that it was half off and half on the screen. Still no warnings. You sure you don’t have a sub-title that’s too complex/too long somewhere?
    What version of DVD A are you using?
    Edward Troxel
    JETDV Scripts
  • Mary Waitrovich
    May 18, 2006 at 1:43 pm
    Thanks Ed. I did need to upgrade, but the real problem is that some of my subtitles are too long, I guess. The error I is get is “too complex due to one or more horizontal lines.” Sometimes making it smaller in size works to clear the error for a particular subtitle, and sometimes I must break it into two to fix it. It’s certainly doable, just time consuming and irritating as I get a result which not the way I want the screen to look.
    Mary
