Activity › Forums › Apple Final Cut Pro Legacy › Overlays disappear after QuickTime Conversion export
  • Overlays disappear after QuickTime Conversion export
    Posted by Chris Linke on November 15, 2010 at 3:37 pm
    I have a sequence with a lot of markers in it. I’m navigating to each marker and exporting a still of that particular frame using “Export > Using QuickTime Conversion…” I have overlays turned on so I can see what each marker is called, and that tells me what to call the still.
    But every time I export, the overlays get turned off and I have to turn them back on again. Naturally, this is annoying.
    Any ideas? I’m on FCP 6.0.6, OSX 10.4.11, 4 x 2.5 GHz PowerMac G5.
    Thank you for your time.
    Chris Linke
    PRC Digital Media
    http://www.prcdigital.com
    Chris Linke replied 15 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 15, 2010 at 4:17 pm
    That’s probably just the way it is…
    Maybe if you perform a match frame, and export the still from the Viewer?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Chris Linke
    November 15, 2010 at 6:33 pm
    I don’t actually want the overlay graphic on the final still. I want it clean, but the overlay guides my file naming.
    Dang. I just tried it on FCP 7.0.2 on OSX 10.6.4. The problem exists there, too. I don’t understand the logic of why overlays must go away when exporting in this manner, but it looks like there’s naught to do about it. Looks like Jerry’s idea is the way to go.
    Thanks, guys.
    Chris Linke
    PRC Digital Media
