Activity › Forums › Apple Final Cut Pro Legacy › Overlaying TC and Clip Name…
Posted by Scott Steyns on April 30, 2008 at 2:13 amI am trying to turn a large number of P2 clips into DV dailies for a client. I know I can use the Time code reader to overlay the TC info but is there a way to automatically overlay the clip name as well.. figured I would ask before I resign to spending days manually doing it..
Cheers,
Jamie Kehoe replied 18 years, 4 months ago 4 Members · 4 Replies -
David Roth weiss
April 30, 2008 at 3:05 amScott,
Sorry, there is no automated method for overlaying clip names on the video in FCP. However, I must ask, is it really necessary? For years film and video professionals have collaborated at the very highest levels by simply using timecode or edgecode with reel numbers, and without using clip names on the media. Is there really anything your client can ID without those numbers?
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Andy Mees
April 30, 2008 at 4:33 amScott
Andres Kiel’s TCR Plus app/filter combo can do this for you. Its a four part process whereby you first apply his filter to your clips as needed, then export an XML of your sequence, then run that XML through his app, and finally reimport the XML as produced by his app back into your project … the resulting sequence will have all the info. Yes its rather a long winded process, but none of the steps are either slow or difficult to perform and it is the only solution available that I’m aware of for what you’re looking for.
https://www.spherico.com/filmtools/tcrPlus/index.html
Cheer
Andy -
Scott Steyns
April 30, 2008 at 5:25 amThe footage was collected with several P2’s and much of it does not have any form of camera reports so there is no real organization to the clips beyond each clips embedded TC. I am providing the raw clips with TC burn and clip name burn so they can identify footage they want to use in the edit.. as the TC’s are all over the place.
I will check out the plug-in and see how it goes..
Cheers,
Scott. -
Jamie Kehoe
April 30, 2008 at 9:02 amI was certain that P2 provides metadata on the card, can’t you somehow write information into this metadata? I would think this could be opened in something like a text editor?
G5 Dual 2.3GHZ
2.5GB DDR SDRAM 400MHZ
Mac OS 10.5.1
2 x 20″ Apple Cinema Display
128MB ATI Graphics
