Activity Forums VEGAS Pro Overlaying bad video frames
  • Overlaying bad video frames
    Posted by Chris Lamela on May 27, 2010 at 5:07 pm
    Hello all, first time user here. I have Vegas 8.0 and am editing a dance video (Flamenco dancing with guitar if you would like to know) and the video has short lapses of junk (garbled frames) that appears in specific frames. I would like to copy the closest good frame and paste it over the following bad frame(s) without disturbing the sound track. I have used section delete successfully with other projects, but that will disturb the beautiful sound track here.
    I have pawed all over Help and Index, and cannot seem to find how to do this.
    Help? Thanks.
    – Chris Lamela
    Mike Kujbida replied 16 years, 3 months ago 3 Members · 3 Replies
  • Aleksey Tarasov
    May 27, 2010 at 6:54 pm
    Vegas doesn’t have built-in commands for replacing bad frames. Only by hands or using scripts. As far as I know, Excalibur and Vegasaur plug-ins have this feature.
  • Chris Lamela
    May 27, 2010 at 7:08 pm
    As additional input:
    I am willing to do it by hand – this particular video is 14 minutes with about 10 bad spots ranging from a single frame to a 15 frames. My idea is to make it appear that the video is ‘frozen’ during those bad spots while the music plays on.
    Thanks again.
    – Chris Lamela
  • Mike Kujbida
    May 27, 2010 at 7:43 pm
    In that case, here’s the approach I would take.
    Insert a Velocity envelope on the video track.
    Place markers (not necessary but I find them helpful in lining things up) at the last good frame of a bad section and the first good frame following it.
    Double-click the line at each marker to add a point.
    Double-click twice more between these two points.
    Right-click each one and “Set to – 0” (velocity, that is).
    Hold down the Alt key to prevent vertical movement and drag point #2 directly under point #1.
    Repeat with point #3 and drag it under point #4.
    What happens is that the video plays along until it hits the first marker at which point the video will instantly freeze until it hits marker #2 when it instantly resumes normal speed.
    Repeat this procedure for all bad spots.
