Activity › Forums › Apple Final Cut Pro Legacy › Overlay went from Canvas to Viewer???
  • Overlay went from Canvas to Viewer???
    Posted by Eric Klassen on August 23, 2005 at 8:26 pm
    I started down the road of setting a bunch of markers throughout the timeline. After doing a bunch of copying and pasting of marker info, jumping around and checking the status of the markers…getting bogged down in tedious details, I noticed that the marker overlay information that initially started out appearing in the Canvas over the video and audio info, now appears in the Viewer all by itself towards the bottom of the frame. I think I hit some keys that made this happen. I need to get that info to be in the Canvas for work flow reasons and I cannot figure out how to get it to go back.
    Thanks in advance for any help on this.
    e
    Eric Klassen replied 21 years, 1 month ago 4 Members · 6 Replies
  • Todd Beabout
    August 23, 2005 at 9:28 pm
    move the clip from the viewer to your timeline. I think somehow you were putting markers on the clip that is in your viewer.
    -Todd Beabout
    Vazda Studios
  • David Bogie
    August 23, 2005 at 9:57 pm
    Todd’s probably correct, easy to check. Sequence markers appear in the timeline, toward the top of the display. Clip markers appear in the clip itself and you can see them in the Viewer and in the copy of the clip that is in the timeline.
    You are probably in for many frustrating hours of more copying and pasting. That’s how I learned about markers, too.
    I will suggest, however, that depending upon markers to hold notes or production hints is not a good idea. Use them for chapters and sync hits. JMHO
    bogiesan
  • Eric Klassen
    August 23, 2005 at 11:08 pm
    Thanks for the suggestions…
    I tried moving the clip from the viewer to the timeline and there was no change. Still getting the clip marker info alone in the viewer and only the video and audio info in the Canvas. Any other suggestions on getting the clip marker info to go onto the Canvas?
    About markers, yea, this has been a really long and tedious process. Any other suggestions for how to most efficiently create a dvd screener with all the scene/take/timecode slate information and a paper log broken down to reference each take? I’m working with green screen footage where we have about 150 takes with very slight changes, but important to note, and it’s basically impossible to keep track of it all unless this marker/text overlay/paper log is done. I can’t think of another way to do it.
  • Bret Williams
    August 24, 2005 at 12:36 am
    Make sure you create chapter markers if you need them for DVD. Or you’ll have another headache.
    Sounds like you had a clip selected when you made your markers. Clip markers (what you don’t want) don’t appear in the canvas. You want sequence markers. Make sure you don’t have anything selected when you create a marker. If you happened to have the clip open or ganged in the viewer, and you create clip markers, then yeah, you’d see them in the viewer.
  • David Bogie
    August 24, 2005 at 1:10 pm
    >t’s basically impossible to keep track of it all unless this marker/text overlay/paper log is done. I can’t think of another way to do it.< Simply not true. Paper, pencil, stickies, still photos, voice/over calls on the takes, heads and tails slates
  • Eric Klassen
    August 24, 2005 at 11:16 pm
    bogiesan,
    Thanks for your thoughts, and thanks for jumping up and down for my best interests ; )
    I’ve been told by Avid users that a kind of template for slate information exists in that program, so I’m thinking maybe there’s a plug-in for FCP, or perhaps there’s a process here that I’m just not aware of. Here’s my situation, and if you have a better way of doing this, please direct me to the nearest exit as you have already begun to do. I am setting markers to get to each take on a reel. On each marker, I describe the take. Doing an hour tape, there’s quite a lot of these. Now, to get that information into a log sheet (from a batch list export), those markers need to be on the clip rather than the sequence, so that’s where I start. Then, in order to create a dvd with chapter markers, I need to re-create those markers on the sequence so they will import correctly into DVDSP. Now, if that isn’t already too tedious and inefficient, I have to go back and create a text layer to describe each take so the person watching the DVD has a note to refer to if they are not referring back to the DVD menu for which take is being viewed (I’ve tried doing a subtitle import for this from the batch list but I can’t get it to work). So perhaps this last step has a solution, but it seems so not right to have to type all this information over and over.
    I am in charge of developing a system for our company that instructs employees in how to develop screeners in an efficient and timely manner. So far, I haven’t come close.
    Thanks for your time, thoughts and guidance.
    eric
