Activity Forums DVD Authoring Overlay significantly lower quality through RCA connection?
  • Overlay significantly lower quality through RCA connection?
    Posted by Jason Brown on February 20, 2010 at 7:31 pm
    Hey Guys,
    I produced a DVD and the client is reporting the overlay (it’s a simple box next to the selection) looks REALLY BAD. He sent me a photo and it does look pretty bad (looks like 3 horizontal lines and it’s not full brightness).
    The ONLY thing I can figure out, as I’ve tested on SEVERAL screens, is that the monitor he’s looking at it on is a CRT television connected to a dvd player with RCA connection. He put it into a player with component connections and said it looks great.
    Any ideas? The box is 16×16 pixels using a color that was selected with Encore’s color picker (so I’m guessing it was NTSC safe) – I did create one that was white and it had the same result.
    I haven’t physically been able to test myself, but was curious if this was a known issue…or if anyone else has experienced this.
    -Jason
    Jason Brown replied 16 years, 6 months ago 2 Members · 4 Replies
  • Michael Sacci
    February 21, 2010 at 8:10 am
    why not post the pic here. it might help,
    this may be a player issue, I have seen real cheap players kill overlays. other then redesigning the button overlay there is really not much you can do.
  • Jason Brown
    February 22, 2010 at 2:45 am
    Let me start by saying that I spent the last 8 hours trying to figure this out and burnt several discs as tests!
    (I’ll attach links to pictures at bottom)
    Has nothing to do with connection – RCA, HDMI, Component…recreated issue with all 3.
    Has nothing to do with player – created issue with multiple players.
    The issue is with 16×9 vs 4×3 mixed with a background.
    First thing I did was put same overlay’s over black. Looked perfect. No problems.
    Second thing I did was put them over a still image OR motion menu (transcoded MPEG2) – problem on both.
    Third thing I found was that problem went away when I changed menu (in encore) to native 4×3 OR changed DVD player to push out 16×9 image.
    Final thing I did was to put all 3 overlay assignments in my photoshop file – =1, =2. and =3. And…get this – 1 and 2 had the problem…but 3 did not.
    So my result was to use ALL =3 and use the same color I’ve been using all along…WORKS FINE on DVD player set to 4×3 LB or 16×9.
    This HAS to be a corrupt install or something…I can’t imagine this is normal…I’m using CS4.
    The overlay in the following image is the 3 circles together…on the left side of the screen, about middle.
    Image1:
    https://www.jbtwist.com/CC/16×9.jpg
    (This is DVD player set to 16×9…there are 3 assigned colors – top =1 – left side =2 – right side =3)
    Image2:
    https://www.jbtwist.com/CC/4x3LB.jpg
    (This is DVD player set to 4x3LB…same overlay same DVD…)
    Again, my solution was to change all overlays to =3 and problem is gone.
    Thought I’d update you, although at this point I don’t need any additional help…disc is on it’s way to the client!
    -Jason
  • Jason Brown
    February 23, 2010 at 3:58 am
    I took the project file to another machine and burned it. It’s experiencing the same problem.
    I’ll completely rebuild with the same background tomorrow and let you know what happens.
    I have the project file (CS4 – about 50MB) if you’re interested in seeing it.
    -Jason
  • Jason Brown
    February 24, 2010 at 4:23 am
    I have another machine at my work…I can recreate the problem with the ONLY consistency being a background image. New Encore project, new Photoshop doc…just copy the pixels. I think either I found a bug or a color match that encore isn’t friendly with.
    I’ll post in the Encore forum as well.
