Activity Forums Adobe After Effects Overlay Edit in between layers
  • Frederic Lumiere
    December 2, 2012 at 5:27 pm
    The only way I’ve figured a workaround is to use a comp as a holding place, drop the edit in it, copy the layer and use CMD-OPT-V to paste it exactly where I want it.
  • Tudor “ted” jelescu
    December 2, 2012 at 7:55 pm
    You can always duplicate a layer, select it, select your reference edit in the Project window, hold Alt and drop over the duplicate layer to replace it.
    Tudor “Ted” Jelescu
    Senior VFX Artist
