Activity Forums Apple Final Cut Pro Legacy Overlay Composite Mode makes for Jaggy Text
  • Overlay Composite Mode makes for Jaggy Text
    Posted by Dave Martin on March 29, 2007 at 8:39 am
    Hi Guys
    When I bring a Livetype IPR in to my timeline (white text with drop shadow) and use an overlay composite mode…the text gets all jaggy. Any way to prevent this?
    BTW-it even happens when I render out the file in the animation codec and import and re render on the timeline.
    Tim
    Martin
    -MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
    -FCP Studio 5.1.1 – QT 7.1 – OSX 10.4.6 – Firmtek Sata Raid- G-raid dv drive
    Dave Martin replied 19 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    March 29, 2007 at 11:53 am
    Are you just laying the LiveType graphic in FC, or are you changing position or applaying any other filter in FC?
    Rafael
  • Thaxter Clavemarlton
    March 29, 2007 at 12:43 pm
    It is essential when attempting to monitor the QUALITY of images in FCP that you use an external NTSC VIDEO Monitor (or PAL, if that’s where you are).
    Especially after you render…
    the Canvas is never high-quality (by design) and should not be used to make determinations of image quality of clips or graphics.
    Video Processing tab.
    “Normal” is default for all Sequences.
    If so, change this to “Best.”
    If you re-position graphics, make SURE the VERTICAL setting for each KEY-FRAME is an EVEN INTEGER (Even Whole Number).
    Examples: 6, not 5 / -124, not -123.27.
  • Bret Williams
    March 29, 2007 at 2:28 pm
    [Thax] “If you re-position graphics, make SURE the VERTICAL setting for each KEY-FRAME is an EVEN INTEGER (Even Whole Number).
    Examples: 6, not 5 / -124, not -123.27. “
    Just something I noticed. With the latest version (maybe 5.1.x) FCP always ensures that it stays on a whole number when dragging in wireframe mode.
    Now apple, was that so freakin hard? Took ya 7 years to come up with that gem of a solution.
  • Dave Martin
    March 29, 2007 at 4:08 pm
    Thanks for all the responses!
    To answer all at once…
    I’m bringing the IR straight in, no position change or movement within Final Cut. No additional filters besides changing the Composite Mode to OVERLAY.
    I have a fairly high quality Sony 20inch PVM series monitor and have been doing motion graphics/editing for around 15 years, although I’m somewhat new to FCP.
    Where do I find the Video Processing Tab again?
    Thanks so much for the help!
    Tim
    Martin
  • Curious Turtle
    March 29, 2007 at 6:25 pm
    You can find the tab in your sequence settings (Cmd-0) and it
  • Rafael Amador
    March 30, 2007 at 2:12 am
    You are not editing in a DV time-line? aren’t you? If so change your sequnce setting to a better codec. DVCPro 50 at least.
    rafael
  • Dave Martin
    March 30, 2007 at 3:25 am
    I’m editing in DVC Pro 50 but I bumped it up to uncompressed to see if that would make a difference…it didn’t.
    Unfortunately, the Video Quality settings didn’t make much difference either.
    I’ve also tried switching the alpha interpretation from straight to black and back…
    Mmmmm…I’ll try a different font and drop the luminance…any other ideas?
    Thanks for the responses!
    Tim
    Martin
