Activity Forums Adobe Premiere Pro Overlapping two multi-track clips
  • Overlapping two multi-track clips
    Posted by Mark Thompson on April 22, 2014 at 11:06 am
    Hi, I’m trying to overlap two clips that each contain 8 mono audio tracks. I drop my main clip onto the sequence (as V1), I see all 8 tracks beneath (A1 to A8). Next I drop the second clip on the timeline as V2 and drag it back over the first clip. The video works as I wanted, i.e. as the higher layer sequence overrides V1. However the Audio tracks from A2 seem to replace those on V1. To get around this I delete (on the timeline) the audio tracks of V2 and I get what I’m after, but it seems like an awkward way to do it – is there a proper way?
    tia, mark
    Paul Neumann replied 12 years, 4 months ago 2 Members · 1 Reply
  • Paul Neumann
    April 22, 2014 at 11:51 pm
    Right click on the 2nd clip in the project bin and choose modify-audio and set the number of tracks to 0. Now that clip will only import as video. You can change it back anytime.
