Activity Forums Adobe After Effects overlapping opacity layers yikes
  • overlapping opacity layers yikes
    Posted by Dawud Ali on December 8, 2010 at 10:52 pm
    hi guys
    i need some advice regarding overlapping opacity layers.
    scenario:
    i have about 3-4 ‘overlapping’ black layers which i want to fade in from mid opacity to nearly full opacity e.g start at 60% then finish at 93%. AND i want them to seem as if they are one image
    Problem:
    the areas were the different layers overlap they appear darker which makes sense when working with opacity BUT i want to make them appear seeming-less even in those overlapping areas
    please if possible and any useful online tutorial explanation
    tnaks in advance :[
    Dawud Ali replied 15 years, 9 months ago 2 Members · 4 Replies
  • Dawud Ali
    December 8, 2010 at 11:13 pm
    doh!wow urber fast response tahnks
    i forgot to mention they are moving layers so is there a better way on cs5 when working with complex shapes and movement, were i could tell Ae i want you to see these as the same object and tell it to ignore overlapping areas??
  • Dawud Ali
    December 9, 2010 at 1:05 am
    ok i need look up track matting now tnks
  • Michael Szalapski
    December 9, 2010 at 4:00 pm
    Track matte info here.
    Alternatively you could precomp your black solids and do the opacity change on the precomp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Dawud Ali
    December 9, 2010 at 10:05 pm
    track matte worked but that would be much simple
    🙂 tnks
