Activity Forums Apple Final Cut Pro Legacy Overlapping 2 shots
  • Overlapping 2 shots
    Posted by David Ashley on July 5, 2007 at 2:31 pm
    Hello, I need to create a still and place it over the top of an existing clip. The still I am wanting to place over the top of the clip is just the bottom part of the frame so I need to cut half out. The real problem I am having is trying to work out how to edit my still shot in photoshop then import it back into Final cut so the selected part being the only viewable part of the frame over the top of the moving image.
    Can anybody help!?
    Jamie Pickell replied 19 years, 2 months ago 2 Members · 1 Reply
  • Jamie Pickell
    July 5, 2007 at 2:57 pm
    Dashley,
    You can make a freeze frame of the image you want, put it on the layer above your main video and crop it in the motion tab. If you want to go the Photoshop route, export the frame as a still image, take it into Photoshop. Duplicate the layer, (I always do this so I have the original image), turn off the base layer, with the duplicated layer as the active layer, cut out the portion you don’t want. You should see the checkerboard background where you have deleted portions of the image. Now use the wand tool to select the checkerboard, then select inverse from the Select menu, then click the channels tab and click on the “save selection as channel” button at the bottom of the channels window and you should see a new channel added called the alpha channel. Save your image as a Targa file 32bit (second window that pops up after clicking save). Import this file into FCP and lay it on top of your primary video layer.
    Jamie
    Dual 2.5 G5
    FCP 5.1
    Kona 2
    XRaid
