Activity Forums Cinematography Overhead Camera Shots
  • Overhead Camera Shots
    Posted by Sam Wheatley on September 1, 2014 at 11:21 am
    I’m looking in to building a rig that would allow me to attach a camera to a horizontal beam so the camera hovers above something looking directly down on to it – a bed, a table, etc.
    I’ve thought about a crane / jib but I was looking for something that would be set up and left there. The set up might also be able to double as a way to hang lights off it.
    I’ve never put something together before like this, I’ve always bought kits that you piece together rather than (what I imagine is the most likely option with this idea of mine) buying the individual pieces and putting them together.
    Weight wise at the moment I’m looking at C300/C500/FS100/FS700 type cameras.
    Have any of you put things together like this? What did you use?
    Thanks a lot 🙂
    (Apologies if this is in the wrong place)
    Mark Suszko replied 12 years ago 2 Members · 3 Replies
  • Mark Suszko
    September 1, 2014 at 10:46 pm
    Auto-Poles. Manfrotto I think owns the name now. They are like high tech versions of the expanding shower curtain rod. great for putting in some lights without stands. Could also hold a LIGHTWEIGHT camera, like a DSLR or go pro.
  • Sam Wheatley
    September 5, 2014 at 11:53 am
    Thanks for the reply. I was looking at those and (assuming I’m looking at the right thing) they seem suitable to be put in doorways.
    A bit of a look around shows they can be modified, though perhaps a couple of C-stands (with the right brackets on the top) and a crossbar. Not sure what that bracket would be mind.
    For those looking in to this thread in the future, I initially found this that might be useful for people looking for similar: https://www.bhphotovideo.com/c/product/980520-REG/impact_basic_varipole_support_system.html
  • Mark Suszko
    September 5, 2014 at 12:27 pm
    Not just doorways; with extensions, they can cover small rooms wall to wall.
