Activity › Forums › AJA Video Systems › Overdriven audio output?
Posted by Joe Murray on January 30, 2008 at 12:02 pmI’ve had my Kona Lh for a few months now – nice bit of kit, But, the RCA/Phono audio out seems a bit hot. It is prone to distortion on loud sections. I can just turn it down globally using the master volume out on my mac but it does seem a bit primitive. Is this common?
Jeremy Garchow replied 18 years, 8 months ago 3 Members · 4 Replies -
Walter Biscardi
January 30, 2008 at 12:26 pmThe Master Volume on your Mac should be set to unity, which is about 3/4 volume. It should not be set to full volume or you can get distortion.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Joe Murray
January 30, 2008 at 1:21 pmMany Thanks. I always had it full up. Is there an exact setting for Unity or just about 3/4 way up.
By the way, I am really enjoying “Stop staring and start grading…..” Full Marks!!
Dual 1.25 MD, FCP 4.02, CW4, 1.25GB RAM, DUAL ATTO, Medea RT480 QT6.3
Walter Biscardi
January 30, 2008 at 1:33 pm[Joe Murray] ”
Many Thanks. I always had it full up. Is there an exact setting for Unity or just about 3/4 way up.”The second to last line in System Preferences > Audio > Output
Jeremy Garchow
January 31, 2008 at 3:37 amThis reason is a good reason not to use your Kona for system sounds. If you need system sounds simply hook a mini plug out of your mac to your mixer. It will solve all these problems as your Kona output won’t be connected to your system which will save you on tape outputs.
Jeremy
