Activity Forums Panasonic Cameras Overcrank
  • Overcrank
    Posted by Ron Dylewski on August 24, 2007 at 12:53 am
    Hi –
    I think I’m correct is saying that I can’t overcrank the HVX200 if it is in an SD mode
    at 24P or 60i. Correct?
    If so, I don’t understand why. It seems to me that, if you can do overcranking in HD, then
    it should be snap in SD…..?
    Ron
    John Fishback
    replied 19 years, 1 month ago
    3 Members · 4 Replies
  • Barry Green
    August 24, 2007 at 12:58 am
    Over/undercranking is only allowed in 720p mode, which is an entirely progressive mode. 1080 is recorded in an interlaced system, and so is 480. 720 is all-progressive, all-the-time, so varying the frame rate is easy to do in 720.
    You can get overcranking and undercranking in DV mode if you use the dub-to-tape feature; shoot your offspeed clip in 720p mode, then dub down from the card to the tape and it’ll preserve the slow-mo or fast-mo nature of the footage.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Ron Dylewski
    August 24, 2007 at 12:34 pm
    Barry –
    Thanks.
    One other query about this camera.
    Can I name a project at the beginning of a shoot and have that name
    attach itself to all the MXF files? In what I’ve done so far, I end up with
    all these bizarre numbered files in my Avid and no way to track what
    project they are associated with. I have an SD card installed, and thought
    this was a rather simple matter…but the logic of it has escaped me thusfar.
    Thanks for any guidance.
    Ron
  • Barry Green
    August 24, 2007 at 2:14 pm
    https://www.dvxuser.com/jason/P2-Name-article
  • John Fishback
    August 24, 2007 at 7:26 pm
    Great article, Barry. I wish we could simply enter the name directly into the camera. Also, in your explanation of the probability of the same number coming up twice, I believe the chance is 1 in 12,960,000 (10x10x10x10x36x36). For example 0001AB is different from 0002AB.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
