Activity › Forums › Adobe Premiere Pro › over exposure effect
  • over exposure effect
    Posted by Mike Pell on January 14, 2009 at 5:27 pm
    In TV shows and documentaries, I have seen where an over exposure type effect is applied as a transition between clips. A few years ago, white flash frames were common but now it seems to be this over exposure as a transition. The frames llok to blow out but must stay within values in the scopes. What’s the best way to accomplish this in Premier CS3? Thanks
    Vince Becquiot replied 17 years, 8 months ago 3 Members · 3 Replies
  • Paul Del vecchio
    January 15, 2009 at 12:47 am
    [Mike Pell] “What’s the best way to accomplish this in Premier CS3? Thanks”
    I would probably just use a white solid and crossfade between that and the footage. obviously you’d have to use the white solid for only a few frames.. 1-5 frames or so, depending on the effect.
    Paul Del Vecchio – Director
    https://www.PaulDV.com
  • Paul Del vecchio
    January 15, 2009 at 1:32 am
    Forgot to mention. You might be able to use a GLOW effect between shots or something, or a dip to white transition if they have it. I’m not sure. I know there’s a dip to black transition.
  • Vince Becquiot
    January 15, 2009 at 7:39 pm
    To get the right effect, I usually just drop the white level input over a few frames at the end of a first clip, and do the opposite on the second clip. Premiere will clip the whites and shouldn’t go over the legal limit. On the chroma side, you can keyframe a saturation effect if you are worried about it going over.
    Save both as separate in and out point presets for easy use as transitions.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
