Activity Forums Avid Media Composer over exposed effect
  • over exposed effect
    Posted by Peter Giffen on July 29, 2005 at 2:32 pm
    What plugin are people using for a nice over exposed dissolve that I am seeing these days.
    Hard to describe but it looks like a dip to color using white but also getting a nice blownout look to the images during the duation of the effect. I assume it is a third party plugin.
    Thanks in advance
    Peter from Halifax
    Jordan O’leary replied 21 years, 1 month ago 3 Members · 2 Replies
  • Satesh Ramjattan
    July 29, 2005 at 10:15 pm
    you could try amping up the gamma inside the color effect. just keyframe so you get a bloom effect.
  • Jordan O’leary
    August 1, 2005 at 10:27 am
    It’s a simple ‘levels’ shift. Open up your level adjustments and lower the ‘White Input” level and you’ll get it. I sugggest bringing up a white card at the VERY end because some of the pixels will trun bright colors when you get close to zero on the “white Input” level. You can do the opposite effect with a dip to black with the “Black Input” level.
