Activity Forums Adobe After Effects Outputting TVC for uk broadcast.
  • Outputting TVC for uk broadcast.
    Posted by Chris Joyce on May 19, 2011 at 1:57 pm
    Hi there,
    I am delivering a TVC today for UK TV broadcast and just wanted to clear a few things up as this is my first time.
    I have the TVC in After Effects at 1920×1080 and have rendered with animation 100% codec. I then import this into Final Cut and export as 720×576, prores 4444, 25fps.
    What I am not sure about is the pixel aspect ratio and if I check animorphic or not. Also does it make a difference if I re-comp to 720×576 and render straight in AE.
    Any help on the subject would be greatly appreciated.
    Chris Joyce replied 15 years, 3 months ago 2 Members · 4 Replies
  • Walter Soyka
    May 19, 2011 at 2:03 pm
    You can do this entirely in AE — and avoid FCP’s scaling.
    Create a new comp using the PAL D1/DV Widescreen preset. Drop your main comp in and scale it to fit. Render directly to ProRes (which should be available on your system if you have FCP installed).
    Walter Soyka
  • Chris Joyce
    May 19, 2011 at 2:58 pm
    Thanks for the quick reply even if it does mean another 3 2hour renders!
  • Walter Soyka
    May 19, 2011 at 3:03 pm
    [Chris Joyce] “Thanks for the quick reply even if it does mean another 3 2hour renders!”
    Yikes! If you’ve already output 1920x1080p25, you can just import them back in, scale them into the comp as above, and output that.
    Walter Soyka
  • Chris Joyce
    May 19, 2011 at 4:53 pm
    Yeah I did realise that after the first one. Thanks for your input.
    After a very long two weeks I my brain doesn’t work as logically as it should.
