Activity Forums AJA Video Systems outputting to UVW-1800, no ref!
  • outputting to UVW-1800, no ref!
    Posted by Trevor Laurence on March 17, 2010 at 4:00 pm
    I’m using FCP 6 to output an uncompressed 8-bit timeline through an Aja Io LA and I’m getting a “No Ref!” on the UVW-1800. I’ve tried print to video and recording from the timeline (everything is rendered) and get a dropped frames message. I’ve output this way before but not in a long time. How do I set up the ref loop to the deck? Is that the problem?
    Trevor Laurence replied 16 years, 6 months ago 2 Members · 2 Replies
  • Will Griffith
    March 21, 2010 at 2:00 am
    composite out of IO —-> ref-in of deck.
    Dropped frames could be numerous things.
    You playing back off your system drive?
    Will Griffith
    Producer
  • Trevor Laurence
    March 23, 2010 at 4:15 am
    Thanks. I got it working. And your thought was right about dropped frames – I wasn’t running it off my internal HD and the Io couldn’t handle the uncompressed through FW800. I rerendered to DV50 codec and was able to run it off the FW800 (internal HD is too full). It’s not uncompressed, but fine for these purposes.
