Activity Forums JVC Cameras outputting timecode on HD110U
  • outputting timecode on HD110U
    Posted by Matt Ruggles on November 6, 2009 at 10:35 pm
    I want to make DVD timecode dubs to DVD to do an off-line EDL. I recorded footage in 720/30P
    2 Things:
    1. I can’t get it to output in letterbox as it is in squeeze mode and won’t let me change it. I would much rather view it in letter box mode if possible.
    2. There has to be a way to display camera data to an external monitor and I am not finding it. Specifically I want timecode displayed so I can make notes on what is shot based on timecode.
    Any help with either of these 2 questions would be great.
    Matt Ruggles
    Scott Sheriff replied 16 years, 10 months ago 2 Members · 2 Replies
  • Scott Sheriff
    November 7, 2009 at 4:41 am
    Matt
    Are you trying to record video out from the camera right to a DVD recorder?
    Give me a call or email if you can’t find the #, I have this cam and a BR-50 deck. I’m sure I can help you out. probably just the switch settings.
  • Scott Sheriff
    November 7, 2009 at 5:04 am
    Quick help
    Menu-other
    ouput char set to on
    When the output char is set to on, the composite video out mimics the VF/LCD display. Toggle the display (display toggle button)to show the TC if it isn’t up. Make sure the TC/UB menu the TC is also set to ON.
    Set the Video Format menu-HD PB Output to what your looking for.
    PB Tape-Auto
    Output Terminal-Auto
    This should give you composite out from the RCA composite gizouta
    970.433.5994
