Activity › Forums › Media 100 › outputting standard def with PDW-F70
  • outputting standard def with PDW-F70
    Posted by Nick Lammers on October 18, 2007 at 3:10 pm
    Hi. I’m planning on renting the Sony PDW-F70 deck over the weekend. My plan is to use it to output an SD, letterboxed signal over firewire for digitizing into a Media 100 system. Original footage shot in 1080. I thought I’d try to be prepared and see if there were any issues or suggestions anyone had that might help me out. Thanks!
    Nick Lammers replied 18 years, 11 months ago 2 Members · 4 Replies
  • Floh Peters
    October 18, 2007 at 3:17 pm
    I have never used XDCam HD, but I have seen that this deck also has HD-SDI (and SD-SDI) out, too, plus RS422. So if you have trouble using FireWire you definitely should be good to go using RS422 and either HD- or SD-SDI.
  • Nick Lammers
    October 18, 2007 at 3:35 pm
    Thanks, Floh. Unfortunately, I do not have the capability to get SDI into the M100. However, I do have a Panasonic BT-LH900AP monitor https://www.bhphotovideo.com/c/product/428936-REG/Panasonic_BT_LH900APJ_Panasonic_BTLH900A_8_4_LCD.html
    Perhaps I go SDI into the monitor and either analog component or composite out? Not sure if the monitor will do this for me or not.
  • Floh Peters
    October 18, 2007 at 3:45 pm
    [Nickel] “Perhaps I go SDI into the monitor and either analog component or composite out? Not sure if the monitor will do this for me or not.
    As far as I can tell the monitor only has inputs, and no outputs. But you should be good to go either using FireWire for Video input and deck control, or by using FireWire as Video in and RS422 as deck control.
    Maybe you should consider upgrading to e.g. a new Media 100 SDe system sometimes, though.
  • Nick Lammers
    October 18, 2007 at 3:50 pm
    [Floh] “Maybe you should consider upgrading to e.g. a new Media 100 SDe system sometimes, though.”
    No doubt about that. A new HD system is definitely in the plans during the next couple of months.
