Activity Forums Apple Final Cut Pro Legacy outputting pre-interlaced video
  • outputting pre-interlaced video
    Posted by David Olsen on December 22, 2005 at 4:36 pm
    So we’re just getting started in FCP – we’ve used a lot of PC type video editing programs such as premiere and we’ve made the big leap to FCP. We’ve captured 10mbps uncompressed video off of our digibeta and imported it into FCP. It appears that the video source is already interlaced, but it seems that when compressing the video via compressor for use in DVDStudio Pro, the video is turning out double interlaced which, of course, makes the video look just awful. The easiest way to fix this (as we really dont want to run a deinterlacer on the video itself) is to turn off the field dominance on compression. We’ve tried to find the controls for this, but we have been unable to locate it. We have found the location where it allows us to switch from top, bottom, progressive or auto but no simple off. Can someone help?
    David Roth weiss replied 20 years, 9 months ago 3 Members · 10 Replies
  • 10 Replies
  • David Roth weiss
    December 22, 2005 at 5:06 pm
    Digibeta is interlaced, lower field dominant, and unless you somehow changed that setting by accident, you should not have to concern yourself with interlacing or deinterlacing. Are you looking at the video on your computer monitor rather a broadcast monitor? If so, then you will certainly see interlacing, especially upon movement. Ignore that, it will not be evident on a TV or broadcast monitor.
    DRW
  • David Olsen
    December 22, 2005 at 5:15 pm
    Actually – it’s on TV after being output to a DVD.
    The video is visibly interlaced on the monitor — and appears to be “interlaced again” when output to a DVD and played. The result is that the video looks very shakey.
    I ran a de-interlace filter on the video which fixed the problem… but instead the video looked more sluggish and not as smooth.
    btw: thanks to anyone that can provide insight
  • David Roth weiss
    December 22, 2005 at 5:25 pm
    In that case, somehow your field dominance has been switched. As I recall, some of the VBR encoding presets are buggy. Try changing to CBR encoding and see if that fixes things. If not, swap field order dominance of your video and try that.
    DRW
  • David Olsen
    December 22, 2005 at 5:28 pm
    Thanks! I’ve tried all the different field orders — but I’ll try CBR and see if that makes a difference.
  • David Olsen
    December 22, 2005 at 7:28 pm
    Hmmm – didn’t work 🙁
  • David Roth weiss
    December 22, 2005 at 8:27 pm
    Very very strange.
  • Peter Wiggins
    December 22, 2005 at 11:48 pm
    David,
    [David Roth Weiss] “Digibeta is interlaced, lower field dominant”
    NTSC maybe, but PAL digibeta is upper.
    Peter
    Now editing The UK Championship Snooker for the BBC
    https://www.peterwiggins.com
  • David Roth weiss
    December 23, 2005 at 1:55 am
    Must be part of that stiff upper lip thing Peter.
  • Peter Wiggins
    December 23, 2005 at 11:39 pm
    No, just an annoyance that people think the whole world revolves round NTSC
    Peter
    Free Motion Templates
  • David Roth weiss
    December 24, 2005 at 1:14 am
    Peter,
    Of course the world revolves around NTSC, thats because the USA is at the center of the universe…
    DRW
