Activity Forums Apple Final Cut Pro Legacy Outputting in 4:3
  • Outputting in 4:3
    Posted by Jan Becker on September 18, 2009 at 8:07 pm
    Hi there,
    I finished editing in native DVCPro HD and now I would like to output it NTSC DV 4:3.
    If I do it in compressor it’s squeezed.
    So what I would like to do is crop the sides, so it’s 4:3 unsqueezed. How do I do it?
    Thank you,
    Jan
    John Fishback replied 17 years ago 2 Members · 1 Reply
  • John Fishback
    September 19, 2009 at 9:15 pm
    I’m not at the office so I can’t give you the exact answer. Look at Compressor’s Inspector. In the Video tab there should be a choice for letterbox in the aspect ratio choices. Or it might be applied as a filter. Check out the manual. Search for letterbox and I’m sure the exact info will be there.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
