Activity › Forums › Apple Final Cut Pro Legacy › Outputting from FCP for YouTube/best practices?
  • Outputting from FCP for YouTube/best practices?
    Posted by Mark Suszko on October 22, 2008 at 7:26 pm
    FCP 6. Got a five-minute DV clip to post on YouTube, having a devil of a time picking the right settings to get a good-looking quicktime MOV under 100 megs with the right frame size for YouTube. Tried export to quicktime, tried export>using quicktime conversion, as well as export>using Compressor, and the amount of choices, aprticularly within Compressor are staggering. Finding the righgt blend of comression plus frame size (720 by 480) is hanging me up. Make up my mind for me? Just tell me which one you KNOW to work well for this task/ walk me thru it? I’d really appreciate the help.
    David Roth weiss replied 17 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Chris Borjis
    October 22, 2008 at 7:44 pm
    this is what I use and it looks spectacular:
    full res (hd or sd, leave it full resolution so 720×480 in your case)
    video: H.264 @ 2,000 kbps
    audio: AAC, @ 168kbps
    You tube will downsize it good and give your video a high quality
    option that will look great.
  • Mark Suszko
    October 22, 2008 at 7:53 pm
    A correction, Youtube wants it at 640 x 480. I tried h.264 yesterday which I agree looks great, but YT rejected it as unknown format.
    Their preferences according to their site are MPEG4 (DIVX or XVID) Windows AVI, Mpeg, with audio as mpeg3. Darned if I can find one of those four formats with the mp3 audio and 640 by 480 size options, all in one spot.
  • Chris Borjis
    October 22, 2008 at 8:35 pm
    [Mark Suszko] “A correction, Youtube wants it at 640 x 480.”
    yes thats right for 4:3 projects so that it properly displays
    and additionally HD needs to be resized to 854×480 so that it letterboxes.
    I just did one yesterday at D1 widescreen (from HD) 854×480 with the codec settings I specified,(I’ve done 5 or 6 that way) so
    I’m not really sure why it wouldn’t work on your end.
  • Tim O’grady
    October 22, 2008 at 10:12 pm
    The new maximum size for youtube videos is 1024MB (still 10 minutes). Here’s a good tutorial:
    https://www.kenstone.net/fcp_homepage/you_tube_redux_gary.html
  • Mark Suszko
    October 23, 2008 at 2:02 pm
    AWESOME link, thanks!
  • Dennis Leppell
    October 23, 2008 at 3:57 pm
    I spent 2 days in compressor hell trying to figure out the best setting template for our situation (hunting/fishing tv show, so lots of busy backgrounds and camera moves). here’s what I came up with:
    export FCP self contained movie.
    drop this movie into compressor
    video settings:
    h.264
    30 fps
    keyframe ever 15
    data rate restrict to 10,000 kb/s optimized for download
    faster encode (got a new 8 core since I set this up, and am doing my first vid w/ it and compressor 3, so I may got multi-pass now)
    audio settings:
    AAC
    Mono
    44.1 kHz
    best quality
    128 kbps
    Now for the various settings you can set inside the inspector window. These were tuned after lots of research and 40-some test vids to combat various things like soft picture, muted colors, with some compromises for encoding time.
    Width: 640
    Height: 480
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 30
    Frame Controls On:
    Retiming: (Good) Frame Blending
    Resize Filter: Linear Filter
    Deinterlace Filter: Better (Motion Adaptive)
    Adaptive Details: Off
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: H.264
    Multi-pass: Off, frame reorder: On
    Pixel depth: 24
    Spatial quality: 75
    Min. Spatial quality: 25
    Key frame interval: 15
    Temporal quality: 50
    Min. temporal quality: 25
    Average data rate: 10.24 (Mbps)
    Brightness And Contrast
    Brightness: 0.000
    Contrast: 5.000
    Sharpen Edge
    Amount: 18.600
    Color Correct Highlights
    Red: 12.000
    Green: 12.000
    Blue: 12.000
    Color Correct Midtones
    Red: 12.000
    Green: 12.000
    Blue: 12.000
    Color Correct Shadows
    Red: 12.000
    Green: 12.000
    Blue: 12.000
    Gamma Correction
    Gamma: 1.100
    You can set all this yourself, or here’s the easy way: download the setting here: https://rapidshare.com/files/156828008/Youtube.setting.html
    See the results here (keep in mind the shakey camera/busy background causes a lot of the artifacts you’ll see):
    youtube.com/watch?v=HW_pmQcrQGc
    https://www.youtube.com/watch?v=HW_pmQcrQGc
    I just encoded a 6 minute vid to upload, and it took 14 minutes on an 2 X 2.8 GHZ quad core w/ 2GB ram, MUCH faster than the 2 hours it took on my G5. File size is 461 GB, well under Youtube’s 1 GB limit.
    If anyone has any improvements on this setting PLEASE let me know.
  • David Roth weiss
    October 23, 2008 at 4:29 pm
    Dennis,
    Are you guys shooting with those disposable cameras they sell at Walgreens? Jeeze, no wonder you need to change so many settings in Compressor.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Dennis Leppell
    October 23, 2008 at 5:07 pm
    disposable, yes….but not from Walgreens. We use XL2 and (now) a Z1U. all shoulder mounted on a rocking fishing boat, makes for not the easiest source footage for compression.
    Following a few guides, including Ken Stone’s, I decided that I had to be as hands on as possible to counteract the recompression that youtube will do (they took away the flash hack, grrrr). Progressive, because it’s viewed on the web. color correction because there’s no simple saturation boost setting (that i know of); youtube seems to desaturate colors a bit after uploading. Boosting the sharpness to counteract it looking soft what they’re done with it. Contrast and gamma to keep from looking washed out. Frame controls were specifically to help with deinterlacing and motion of a constantly moving camera.
    The whole process leaves a video that doesn’t look all that good when played back on the computer, but is fairly decent once recompressed by youtube.
    Yea, our footage is about the worst you can use for compressing for the web; this was my attempt to make it look passable on youtube, and compared to stock settings from youtube, it looks drastically better.
  • David Roth weiss
    October 23, 2008 at 5:34 pm
    I was joking with you Dennis and I commend you for putting up with my humor.
    On a more serious note, web compression is a black art, and it can take ages to find tried and true solutions that work beautifully. Of course it does help to have perfect video from the start, and that is unfortunately all too rare these days, as anyone who owns a camera can call themselves a professional cameraperson.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
