Activity › Forums › Adobe After Effects › Outputting comp layers to a shot list text file
Posted by Frederic Lumiere on December 19, 2012 at 8:17 pmAnyone aware of a script that allows you to generate a shot list (with timecode, duration, etc.) from a comp?
Frederic
Frederic Lumiere replied 13 years, 8 months ago 3 Members · 8 Replies -
Frederic Lumiere
December 19, 2012 at 10:49 pmHi Dave,
Thanks for the response!
Yes, I need to do it in AE. 750 layers, spread across 9 screens for a total of 13K resolution… FCP, Avid, Premiere couldn’t handle it.
All I really need is output what i see:
Layer name, In, Out, Duration
F
Roland R. kahlenberg
December 19, 2012 at 10:49 pmI thought you’d seen this b4 – https://forums.creativecow.net/thread/2/1008244
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Walter Soyka
December 20, 2012 at 5:34 am[Frederic Lumiere] “All I really need is output what i see: Layer name, In, Out, Duration”
Three thoughts:
You can do all this with a keyboard macro. You mentioned FCP, so I’ll assume you’re on a Mac. Look at Keyboard Maestro. Here are the keystrokes you’d need:
Return (to make layer name editable)
Cmd-C (copy)
Cmd-Tab (to Excel)
Cmd-V (paste)
Cmd-Tab (back to Ae)
I (go to layer in)
Opt-Shift-J (Go to time)
Cmd-C (copy)
Esc (close Go to time)
Cmd-Tab (to Excel)
Cmd-V (paste)
Tab (next field)
O (go to layer out)
Cmd-C (copy)
Cmd-Tab (to Excel)
Cmd-V (paste)
Return (next line)
Home (beginning of line)
Cmd-Down (select next layer)Wash, rinse, repeat. You’ll have to calculate duration yourself from the in and out points. You should be able to grab them from the Time Stretch dialog box, but you can’t reach that from the keyboard; your macro would have to navigate the menus Layer > Time > Time Stretch…, and then a Tab and Cmd-C and Esc should work, as it does for the Go to time window.
Alternately, you could swing by the Expressions forum. This can’t be done with an expression, but it should be a very simple script to walk down the timeline and grab the information you’re looking for, and you may be able to find help or hire someone for a couple hours to pull it together for you.
Finally, you might be able to parse this out of Paul Tuersley’s pt_OpenSesame script — but that may be a lot more work than the other options.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Frederic Lumiere
December 23, 2012 at 8:46 pmI need to output a comma delimited file for production bible.
Frederic Lumiere
December 31, 2012 at 5:24 pmWow, really there is no way to output a shot list from a comp?
I can basically see it in front of me when looking at a comp but I can’t output it to a text file…
Frederic Lumiere
January 2, 2013 at 6:44 pmHi Walter,
Thanks so much for your help on this.
I’m trying Keyboard Maestro and the copy and paste works fine when I record it but it doesn’t when I execute it… It pastes the last thing in the clipboard.
Any ideas?
F
Walter Soyka
January 2, 2013 at 7:11 pm[Frederic Lumiere] “Thanks so much for your help on this. I’m trying Keyboard Maestro and the copy and paste works fine when I record it but it doesn’t when I execute it… It pastes the last thing in the clipboard.”
Sorry, I have no idea. I just tried it over here, and it works fine.
Keyboard Maestro has a stack of fancy clipboard features — perhaps one of them is enabled?
Walter Soyka
Frederic Lumiere
January 2, 2013 at 10:56 pmSo strange, I tried everything and the copy/paste function isn’t working for me.
Which version of AE do you have? I use CS6
