Activity Forums Adobe After Effects Outputting ALPHA overlook
  • Outputting ALPHA overlook
    Posted by Jon Hutton on August 6, 2008 at 7:03 pm
    Hey, having some difficulty rendering out a simple sequence with an alpha channel, I created some particle smoke and outputted over a transparent bg, animation – millions color+ – straight unmatted, like I have many times before, but for whatever reason it is not giving me my alpha channel and giving a black bg and white edging around the smoke with alot of stair-stepping, so I thought weird try again, same thing, so I ran a test of just a red circle over a transparent background, same result, so it is not the particle that is doing it to me, I feel I have been staring at a computer screen for too long and am over-looking something simple, any takers?
    Mike Zimbard replied 18 years, 1 month ago 2 Members · 2 Replies
  • Jon Hutton
    August 6, 2008 at 7:59 pm
    Ha figured it out, I guess it was working all along, but when I was opening it in quicktime it was giving me the white edging, it was also giving me the same thing when i was doing a quick preview in the OS, so I figured what the heck just drop it in Final Cut and see what happens, and of course it worked no problem, I dont know why it is showing up in quicktime like that though, waste of time, do you have any ideas why it would show up like that? Usually when I preview it in the OS it will give me the transparency, oh well.
  • Mike Zimbard
    August 7, 2008 at 1:38 am
    What you’re seeing in QT or the OS is absolutely correct as this is the way a straight alpha is displayed outside of a compositing application. For a great explanation of straight vs. premultiplied alphas take a look at this podcast from Aharon Rabinowitz. It should be able to answer all of your questions:
    https://library.creativecow.net/articles/rabinowitz_aharon/straight_vs_premult.php
