Activity › Forums › Apple Final Cut Pro Legacy › Outputting 720/24p for HD Broadcast in the US & Europe .:. 24P vs 30P
  • Outputting 720/24p for HD Broadcast in the US & Europe .:. 24P vs 30P
    Posted by Jared Scott on September 11, 2009 at 3:02 pm
    I’m shooting 720/24p with an HMC-150. All the footage will be edited in a 23.98 timeline.
    This is for both HD broadcast in the US and PAL broadcast in Europe.
    Will the outputs/mastering be problematic in any way… It is essential that this has the ‘film look’ (also shooting with 35 adapter and primes)
    I have read a lot about 24 vs 30P – it seems it is a workflow thing. We have already shot some stuff in 24. Could make the switch to 30P if it will be a problem for a broadcast master (both in the US and Europe)
    I would also like to include some slow motion. Should I shoot that at 720/60p then import directly into 23.98 timeline – or is there a conversion I need to do — or a better way to get slo-mo — It seems the 24p slo mo isn’t ideal…
    thanks.
    Jared
    Bouke Vahl replied 17 years ago 2 Members · 1 Reply
  • Bouke Vahl
    September 12, 2009 at 8:41 am
    Jared,
    If you are shooting 24p for the ‘film look’, forget it.
    the DOF will give you the film look, as well as a zillion other things.
    Added pulldown is a trick that has been invented to convert film to NTSC video, and has nothing to do with a theatre experience.
    Also, forget about pulldown in PAL. The whole idea behind 24P in video is to:
    a: be able to go to Film without speed change (except the 23.976 to 24)
    b: be able to go to NTSC with pulldown
    c: be able to go to PAL with a slight speedup (24 to 25)
    If you are going to add 30 fps to the mix, you need a very expensive / difficult / quality loosing conversion.
    (Especially the mix will make things very hard)
    Don’t do it, stick to 24 and play out @ 25 to Pal
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
