Activity Forums Apple Final Cut Pro Legacy Outputting 25fps to 50i through Kona
  • Outputting 25fps to 50i through Kona
    Posted by Michael Nichols on October 10, 2010 at 4:14 am
    Anything special I need to know with regards to sending footage that was run through compressor originating in 23.98 to 25fps, then out to 625 PAL digibeta @50i?
    I assume the Kona will interlace for me, but I want to make sure I don’t hit any roadbumps. I used compressor to go from 23.98 to 25fps while staying at 100% of my original run time.
    Michael Gissing replied 15 years, 11 months ago 2 Members · 3 Replies
  • Michael Gissing
    October 10, 2010 at 6:33 am
    Yep Kona3 goes from 25p to PAL SD 50i in my experience no problems. I presume your sequence is set to field order NONE
  • Michael Nichols
    October 11, 2010 at 1:03 am
    I am compressing with Compressor to go from 23.98 HD to 625i25 (50i PAL?)
    When I make my pro res file, should I keep the dimension 1920×1080 and let the Kona downconvert and scale?
    This way, I would only have to compress one file, correct? I have to deliver letterbox and anamorphic PAL digibeta and I am originating 1080/23.98 Pro Res 4444.
    Right now, I am running my file through compressor with 2 settings:
    625 4:3 letterbox @25fps (100% of source speed)
    625 16:9 Anamorphic @ 25fps (100% of source speed)
    Should I do something different?
    Abel Cine Tech – Rental Coordinator
    Phantom HD Gold • Arri Alexa • Red MX •
    212.462.0163 • mnichols [at] abelcine [dot] com
  • Michael Gissing
    October 11, 2010 at 1:47 am
    Kona will do a better downconvert and in real time. I would leave Compressor doing just the frame rate conversion and stay 1920 x 1080
