Activity › Forums › Panasonic Cameras › outputting 16:9 in letterbox sequence
Posted by Peter Carroll on May 16, 2006 at 3:30 pmIs there any way to minimize loosing sharpness/resolution when outputting 16:9 footage in a letterbox sequence? I am surprised at how much softer it looks.
Thank you.
Peter Carroll replied 20 years, 4 months ago 3 Members · 7 Replies -
Noah Kadner
May 16, 2006 at 3:39 pmLetterboxing to? HD is 16:9 if you are going to standard definition you can choose 16:9 or 4:3 letterbox- what are you trying to do?
Noah
Peter Carroll
May 16, 2006 at 3:54 pmI have SD footage shot in the anamorphic mode of my new HVX 200. Since the project will be viewed mostly on conventional 4:3 TVs I need to output a letterboxed master. I am using Final Cut 4.5, and when I create a letterbox sequence the image sharpness deteriorates. Is there any way to minimize this?
Noah Kadner
May 16, 2006 at 4:13 pmAre you outputting to DV NTSC, how will it be played back? Please let us know your SD settings- we can’t see your computer from here. DVDs can be encoded at 16:9 native BTW.
Noah
Peter Carroll
May 16, 2006 at 4:52 pmNoah, thanks for being patient with me.
Yes, I am outputting DV NTSC and I would like to release the show on DVD.
The clip item properties are Anamorphic, DV-NTSC 720X480. -
Roddy Jamieson
May 16, 2006 at 5:04 pmLet your DVD do the letterbox when you author. Just set your track display to 16:9 letterbox and provided the end user’s DVD player is correctly set they will have a letterbox on their 4:3 screen. If they have widescreen TV then no problem.
Roddy Jamieson
Noah Kadner
May 16, 2006 at 7:12 pmExactly- peek into the manual about 16:9 anamorphic DVD authoring. It will look a lot better than 4:3 letterbox. Quick background on why this is so:
https://gregl.net/videophile/anamorphic.htm
Noah
