Activity › Forums › Blackmagic Design › Outputing to the Blackmagic codec without a card
Luke Maslen replied 20 years, 11 months ago 5 Members · 12 Replies
David Mallin
October 17, 2005 at 8:52 pmAre there known issues with using Blackmagic cards with 10.3.9? Or is just not formally tested?
I already had my system at 10.3.9 when I bought my card, and there is no way I’m going through the process to move it back to 10.3.8. Also, all the new stuff Apple is releasing, such as iTunes, requires 10.3.9 to install.
David -
Luke Maslen
October 19, 2005 at 4:56 amHi David,
If your system is running fine, then that’s great and you can keep using it. We’ve performed testing on Mac OS X 10.3.9 and it basically worked OK. However we have received a lot of feedback from customers regarding a range of inconsistent problems with Mac OS X 10.3.9 and so we suggest using either a Panther, FCP 4.5 and DeckLink 4.8.1 combination or else Tiger with FCP5 and DeckLink 5.1.1. Hopefully your system will continue to perform well.
Regards,
Luke Maslen
Blackmagic Design
