Activity › Forums › Avid Media Composer › outputing to DVD with xpress DV
  • outputing to DVD with xpress DV
    Posted by Tito Haggardt on May 9, 2006 at 11:23 pm
    is there a best way to output my project in xpress DV. i know i am limited by the software but would like the best results possible. also any other suggestions or referals to past posts would be appreciated especially those regarding capturing, rendering and resolutions with the express DV program.
    thanks tito
    Jon Zanone replied 20 years, 4 months ago 2 Members · 3 Replies
  • Jon Zanone
    May 10, 2006 at 11:16 am
    What other software do you have? Sorenson? DVDit or ReelDVD?
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Tito Haggardt
    May 11, 2006 at 12:13 am
    aloha
    i have sorenson squeeze 4, up graded from the lite version and DVDit that came with the xpress DV.
    tito
  • Jon Zanone
    May 11, 2006 at 11:39 am
    Install sorenson if it isn’t already…
    Export a QT reference (right click on your sequence, send to>encoding>sorenson)
    You’ll get a dialog box – select your path (click set) and check your settings (click options)
    Click OK – Avid will create a QT reference and open Sorenenson.
    In Sorenson (depending on which version you have, you’ll have a little ‘wrench’ icon or go to tools and filters (I think…) make sure auto de-interlacing is OFF.
    apply the MPEG-2 options, and keep your data rate around 4500-5000kbs, 6 I-frames (for high motion), or 12 I-frames (for talking heads) and program stream
    Squeeze it!
    It will put your file in the same place you put your QT ref, so pay attention to where you sent it out the Avid.
    You now have a .mpv file and a seperate audio file.
    I use ReelDVD (it came with Avid) and Adobe Encore to burn the DVD.
    Also, check out Avid’s forum site (https://www.avid.com/exchange/forums/thread/4408.aspx)
    There’s a wealth of info – scroll down to the ‘How to DVD’ section.
    Jon
