Activity › Forums › Apple Final Cut Pro Legacy › Outputing Letterbox from Anamorphic sequence
  • Outputing Letterbox from Anamorphic sequence
    Posted by Ashley James on January 23, 2006 at 6:45 pm
    I’m a newbie to Final Cut. I’m cutting a documentary shot with the Panasonic DVX 100 in 16×9. I’ve captured and edited with DV Anamorphic, but I want to export/print to tape for the client to see it letterboxed on a 4×3 television. Can someone describe a workflow to accomplish this, or do I have to go back and capture again?
    Kevin Monahan replied 20 years, 8 months ago 4 Members · 4 Replies
  • Aaron Neitz
    January 23, 2006 at 7:14 pm
    Make sure the “anamorphic” flag is checked in your bins for the media, just drop it into a regular DV-NTSC preset sequence and it’ll automatically letterbox.
  • Kevin Monahan
    January 23, 2006 at 7:28 pm
    Of course, you’ll have to render your whole show first.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Ben Holmes
    January 23, 2006 at 10:59 pm
    No need to recapture! Heaven forbid…
    The simplest thing to do is to render the entire timeline as a single file (or a sequence of them if necessary). This is simply accomplished by using export quicktime.
    Open a new sequence and set this to be 4:3 (uncheck anamorphic tab)
    Import the previously exported files back into fcp. Open the properties for these files (or file) and check the anamorphic tab. Drop this file(s) into the 4:3 sequences, and it will be letterboxed!
    The nice thing about this workflow is the original export is nice and quick (no conversion), and the new letterboxed timeline will run in real time on most modern macs…
    Happy outputting!
    Editec Broadcast Editing Ltd
    EVS and FCP specialists
    Current Mac systems All Dual 2.7Ghz with Kona 2 and Digital Voodoo cards, 6Gb Ram, Sapphire, SCSI320 Medea and Huge Arrays.
    FCP projects include Sky TV coverage of the Ryder Cup and US Open Golf – Live OB specialists. Edit/slomo vehicle.
    http://www.editec.co.uk
  • Kevin Monahan
    January 24, 2006 at 11:43 pm
    [Ben Holmes] “The nice thing about this workflow is the original export is nice and quick (no conversion), and the new letterboxed timeline will run in real time on most modern macs…”
    I’d still render it. In my experience, RT output is not always the best quality, even if in Safe RT>High.
    Kevin Monahan
    fcpworld.com
