Activity › Forums › Adobe Audition › Output volume issues.
  • Output volume issues.
    Posted by Mark_c on August 17, 2005 at 6:21 pm
    I have just started recording with Audition and I have come across something odd. When I play back my recordings they seem to be extremely quiet. For example, if I play a CD through my monitors, a listenable level on the volume control might be 4, whereas when I playback audio from Audition this would need to be turned up to 8-9 for approximately the same volume.
    To test this I recorded a track which was at max input volume, i.e almost clipping throughout. When compared to the CD playback it is still noticeably much quieter.
    Does anybody know why this might be? I could provide more information on request if I have missed anything vital out.
    Thanks, Mark.
    Willie Toth replied 21 years, 1 month ago 2 Members · 3 Replies
  • Willie Toth
    August 17, 2005 at 11:05 pm
    Mark,
    Is the playback from your CD and Audition going through the same soundcard? Check your computers mixer and see where the levels are set … Most CD’s are normalized to -.1db … The industry standard used to be -6db … Try normalizing your track to -.1 and then compare the two … I wouldn’t even worry about volumes until mixing and then final mixdown ………. WILLIE
  • Mark_c
    August 17, 2005 at 11:25 pm
    Thanks for that, I was under the impression that if I just mixed it right I could worry about the volume later. I have just found that if I normalise as you suggested the volume gets to the level I had expected.
    Thanks.
    Mark
  • Willie Toth
    August 18, 2005 at 12:25 am
    Mark,
    No prob, glad I could help ……… WILLIE
