Activity Forums Apple Final Cut Pro Legacy Output Video Darkens During Text Onscreen
  • Output Video Darkens During Text Onscreen
    Posted by Nicklaus Greggsen on July 10, 2012 at 10:45 pm
    This is one I haven’t found anything on the internet about —
    I produce instructional videos and use the OUTLINE TEXT function (I am using Final Cut Pro 7, FYI). When the text appears onscreen, right at the cut where the text starts, the video gets perceptibly darker. I can’t figure out why, as this isn’t the case when viewing the video in the canvas viewer.
    Anyone know why this is happening and how to fix it? I export my finished videos using Quicktime Conversion to 1080p resolution using AAC audio compression and use the Quicktime ProRes 422 [hq] codec.
    I’m at my wits end here and my employer really wants me to resolve the issue.
    Everton Sebben replied 12 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Nicklaus Greggsen
    July 11, 2012 at 8:44 pm
    Anyone have any input?? I’m dying here.
    Whenever the text effect comes in, the screen visibly darkens when viewing the video i’ve exported, while in the canvas viewer the video never did any such thing. please help. 🙁
  • Michael Gissing
    July 12, 2012 at 12:55 am
    What is the source codec from camera and the sequence settings you are using.
    What you are exporting is weird but more on that later
  • Nicklaus Greggsen
    July 12, 2012 at 4:34 pm
    here’s my workflow – I am recording in full HD at “60p”, which as I understand really isn’t 60p in reality – but thats not important.
    The camera I’m using is a Sony HDR-CX580V (and prior to that a CX560V). I convert the .mts files the camera records into .mp4 files via handbrake, 1920×1080, whenever possible using the ProRes422(HQ) codec or H.264, then run that through MPEG Streamclip
    Then I import the footage into FCP 7, do my editing, then when I’m done, I export the file “Export Using Quicktime Conversion” and export to .mov using the ProRes422(HQ) codec and select “Deinterlace” when that is an available option, then take the .mov file through MPEG Streamclip again to convert the .mov to an .MP4 file (with deinterlace selected) at 1080p to upload to youtube.
  • Mabel Lau
    July 13, 2012 at 8:13 am
    Try using Compressor to export your video to ProRes 422, using Quicktime Conversion will darkens your video quite a bit.
  • Nicklaus Greggsen
    July 13, 2012 at 4:20 pm
    let me clarify, the video gets visibly darker from one frame to the next when the text comes onscreen – I am not 100% convinced that’s it, because the video darkens while the text is there and then lightens once the text effect ends.
  • Nicklaus Greggsen
    July 16, 2012 at 8:53 pm
    i’ll try exporting using compressor though and see if that solves the problem
  • Everton Sebben
    April 8, 2014 at 12:19 am
    Man, im having the exactly same problem here. Did you find any answer yet? \\o//
