Activity Forums Apple Final Cut Pro Legacy Output to PAL ?
  • Output to PAL ?
    Posted by Dennis Dean on July 11, 2008 at 3:06 pm
    Just installed FCP Studio (I’m a newbie to FCP) and already find myself having to quote a project to be taped in the states NTSC? but output at 16×9 PAL for UK use.
    If I record HDV and edit that in FCP STUDIO – can I output it as PAL ? I’m thinking the answer is easy – should be no problem – but thought I’d better check.
    Regards,
    Dennis Dean
    Dennis Dean replied 18 years, 1 month ago 2 Members · 3 Replies
  • Dennis Dean
    July 12, 2008 at 4:45 pm
    Thanks to all who helped with this
    Dennis Dean
  • Nan Mcelroy
    July 22, 2008 at 5:39 pm
    Hi, Could you summarize the info you received for your question?
  • Dennis Dean
    July 23, 2008 at 1:16 am
    Yes – absolutely nothing. Sorry I can’t be more helpful if you have the same question I had. From all I’m reading – haven’t had time to test – I should be able to do this. I’ve also read I will get better quality shooting PAL to start with. But here’s another question -this is for online tv in Europe. Do we need PAL at all?
    Dennis Dean
