Activity Forums Apple Final Cut Pro Legacy output to DVD?
  • Todd Beabout
    May 22, 2006 at 2:30 pm
    You might want to try this thread:
    https://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=200
    -Todd Beabout
    Vazda Studios
  • Zeliha Bozkurt
    May 22, 2006 at 3:26 pm
    Hi
    Thank you for the reply but the below link you sent me doesn’t direct me to a thread it takes me to the Creative Calf forum page.
    Could you please try to sen it to me again.
    Zee.
  • Todd Beabout
    May 22, 2006 at 4:24 pm
    Sorry about that.
    You will need to export your program using compressor to MPEG-2. Then import that into DVDSP and create your DVD. It is a fairly streamlined process, but let us know if you have any problems along the way.
    -Todd Beabout
    Vazda Studios
  • David Bogie
    May 22, 2006 at 6:54 pm
    Start by opening the FCP manual and reading the DVDSP parts.
    Then open the DVDSP manual and read the FCP parts.
    Export out of FCP using reference. Using self-contained or MPEG2 encoding are not necessary unless you have specific reasons for using those methods. You don’t or you wouldn’t be asking this question. this way.
    Import the reference into DVDSP, drop it onto the timeline and push the burn button. What happens after that is between you and the manuals. You have lots of choices you can make. Or not.
    While the process is streamlined it’s not simple at all and there are many ways to screw it up.
    bogiesan
