Activity Forums Apple Final Cut Pro Legacy Output Solutions for DV
  • Output Solutions for DV
    Posted by Trent Wunstel on June 28, 2005 at 1:31 am
    Just curious to see what people are using for DV output. I know most people go through a DV cam or A/D box. What is the cheapest solution to kill latency? What is considered the best solution for under $500? I am looking for a solution that does not use a DV cam.
    My new system on the way.
    G5 2.7 Dual.
    Thanks for the great input guys.
    Arnie Schlissel replied 21 years, 2 months ago 4 Members · 3 Replies
  • Kerry Brown
    June 28, 2005 at 4:11 am
    Canopus ADVC-100 or 300
    KB
    KB
  • Shane Ross
    June 28, 2005 at 5:20 am
    I’ll second the ADVC-100 / 300 suggestion.
    Very solid. Not expensive.
  • Arnie Schlissel
    June 28, 2005 at 4:33 pm
    [Trent Wunstel] “What is the cheapest solution to kill latency?”
    Firewire will always have issues with latency. It’s inherent in the technology. The digital signal has to move to whatever box is doing the AD conversion, & then it takes a few frames for the signal to get converted.
    If you need a zero latency solution, you have to install a PCI card in your desktop. Look at AJA’s Kona, Auroara’s Pipe, or Black Magic’s Decklink.
    Arnie
    https://www.arniepix.com
