Activity Forums Telestream output sizes in wirecast
  • output sizes in wirecast
    Posted by Camilo Ramos on May 4, 2010 at 2:18 pm
    I am trying to create some videos for on-demand viewing. I haven’t been able to record on sizes or aspect ratios other than 4:3, 16:9, or HD. Can anybody please advice on how can i create or record a movie that’s for example, 700 x 500 – squared pixels? I need this in order to include the video inside a flash page that has already been designed.
    Thanks in advance…
    Craig Seeman replied 16 years, 3 months ago 2 Members · 3 Replies
  • Craig Seeman
    May 4, 2010 at 10:00 pm
    You can set the frame size to whatever you want in the Broadcast settings.
    The issue you’ll run into is that the input aspect ratio frame sizes are based on video frame sizes.
    Output can be anything you want though.
  • Camilo Ramos
    May 6, 2010 at 12:50 pm
    Thanks… So in other words, if I choose a size other then the usual NTSC/PAL – SD/HD formats, the result will be distorted ?
  • Craig Seeman
    June 18, 2010 at 3:45 pm
    There’s too many variables on that to say for sure.
    You’re confusing input “canvas” with encoder output.
    Wirecast will output whatever frame dimensions you set it for in the encoder.
    It’s up to your Flash player to interpret Wirecast output.
