Activity › Forums › Boris FX Particle Illusion › Output Size Problem in PIse
  • Output Size Problem in PIse
    Posted by Kerry Cramer on June 15, 2010 at 5:28 pm
    Hey, there…I’m working with a 720×480 background video – and set the stage size accordingly, but when I record, although it does save in 720×480, a portion of the result is cut off and only shows up as black space. Specifically, a section of the right and top sides of the saved video is just…gone. I’ve tried output in AVI and WMV as well as adjusting the stage size up and down, but nothing seems to make a difference. So what am I doing wrong? Thanks…
    Kerry Cramer replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
