  • Posted by Ronn Kilby on May 3, 2010 at 11:48 pm
    I’m trying to output a project 1920×1080. I’ve set the stage size to those dimensions, and also the default size. The fields next to Stage Size keep switching back to 320×240. It outputs a file that is 1920×1080, but the PI image is 320×240 in the center of that area. How can I get it fill the raster? PI 3.0.4.1
    Alan Lorence replied 16 years, 4 months ago 2 Members · 1 Reply
  • Alan Lorence
    May 4, 2010 at 6:33 pm
    In the project settings dialog you’ll see a box for stage width, then one for stage height, then a pulldown menu with a list of common sizes. The width and height boxes are what matter — the menu is for faster setting of the size you want.
    So if the pulldown says “320×240” but the width box says “1920” and the height box says “1080”, 1920 x 1080 is the size.
    Are you using a background image for the layer, or is it only particles? If it’s only particles, I don’t know why it would be using only the center 320 x 240.
    Alan.
    http://www.wondertouch.com
