Activity › Forums › Adobe After Effects › output settings
  • output settings
    Posted by Dart on May 10, 2005 at 11:28 am
    Are the composition settings over ridden by the settings set in the output module? So if a composition set up is set to half resolution, yet the render resolution setting are set to full…would the render have the same result in as if both had been set to full resolution?
    Serge Hamad replied 21 years, 4 months ago 2 Members · 1 Reply
  • Serge Hamad
    May 10, 2005 at 12:52 pm
    If you check “Current Settings” in the Render Settings window for Quality & Resolution, then your render will have the same value then your comp settings.
    Salut.
    Serge
