Activity Forums Adobe Premiere Pro Output settings for delivery
  • Output settings for delivery
    Posted by Thackston Addy on August 31, 2015 at 7:26 pm
    I rec’d the following specs for uploading a video to a broadcast cable station:
    File settings:
    MPEG2
    4×3 (720 x 486)
    My video is native 1920×1080 at 23.976.and this is the first time I’ve output for broadcast in Premiere.
    What should my export settings be to achieve best quality? The 720×486 is throwing me off and the aspect ratio does not look good when I change it from square to 4:3.
    My current settings:
    Format: MPEG2 √
    Preset: Custom
    Width: 720
    Height: 405
    FR: 23.976
    pulldown: 2:3
    field order: progressive
    aspect ratio: usually square but changed it to 4:3 which looks awful.
    Thanks in advance. I sent a note to the station but have not heard back.
    Jon Doughtie replied 11 years ago 2 Members · 1 Reply
  • Jon Doughtie
    August 31, 2015 at 7:58 pm
    You have two options. You can letterbox your video so they will see the full image or you can crop and lose the sides of the image. SD is not square pixel; the PAR is .91 (rectangular).
    It is peculiar they are only specifying an SD format. I would ask if they have any HD options.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
