Activity Forums Adobe Premiere Pro output setting for Premeire
  • output setting for Premeire
    Posted by Christopher Loehrer on March 18, 2008 at 3:04 pm
    I need to out put the green screen footage that i shot. I need the best compression (or no compression settings) that work best with keying out the green in after effects. right now when i bring in an AVI i get Raster lines and just not a smooth edge to my reletively unmoving subject.
    I have played around a bit with setting, but am not satisfied. I am not sure if i should interlace or deinterlace. AVI or WMV? (is there a tutorial on this?)
    Anyone out there who has had success with this you input would be great.
    i am in CS2.
    Chris
    David Dobson replied 18 years, 6 months ago 5 Members · 6 Replies
  • Vince Becquiot
    March 18, 2008 at 4:16 pm
    If this is interlaced, well, that’s your call. I’ve seen many people here at the cow recommending a deinterlace. While that’s great for compositing, you’ll also get a big hit on the resulting resolution.
    I now almost exclusively work in progressive, but I’ve never deinterlaced unless it was going to the web.
    I bring the native footage to AE and work in a square pixel composition. I do my Keying with Primatte which I can’t recommend enough. I also do all my backgrounds in AE, since that allows me to add a light wrap and color matching to sell the shots. I then export with Quicktime Animation (no need for alpha channel).
    That’s about it.
    Cheers,
    Vince
  • Jeff Brown
    March 18, 2008 at 5:11 pm
    What’s the original footage? I’d stay with that format, unless it requires re-compression. For robustness, export file sequences; PNG will save some space and is uncompressed. If you’re using interlaced footage, keep it interlaced.
    Anyone recommending de-interlacing for keying or compositing probably means: convert fields to frames (i.e., 30 FPS to 60 FPS), key, re-interlace (60 FPS back to 30 FPS). Not really necessary with contemporary software.
    That said, I haven’t used AE in several years (Combustion is my compositing app of choice), so your results may vary.
    -jeff
    Jeff Brown
    Fire Mist Media
    http://www.firemist.com
  • Vince Becquiot
    March 18, 2008 at 5:51 pm
    Jeff,
    Just a quick comment on the “Progressive Scan” method you mentionned. You will indeed keep the full resolution, but you will also get a “jumping” effect on static images and logos, so I gave up on that method as well.
    Cheers,
    Vince
  • Jeff Brown
    March 19, 2008 at 2:42 pm
    Vince– I’ve never bothered with the method myself. I just let the software deal with fields. ‘Course, if you’re using steam-powered software instead of that new-fangled electric stuff, you might need the workaround…
    -jeff
  • Jon Barrie
    March 19, 2008 at 9:49 pm
    Is there a reason you can’t import the original clip into After Effects?
    Your clip quality is only as good as its original digitized format. If it’s DV or HDV you won’t get a better quality by exporting it to uncompressed. It will just be a larger file with the same pixel info.
    Key it with Keylight. check the adobe video tutorials on how to use it.
    – Jon 🙂
    How many editors does it take to change a light bulb?
  • David Dobson
    March 20, 2008 at 1:35 am
    Any reason not to key it in Premiere Pro? If the key is decent you can get great results with it(CS3 anyway). Otherwise – keep it in the native format as long as possible.
