Activity › Forums › Adobe After Effects › Output Rendering
  • Steve Roberts
    November 4, 2009 at 7:07 pm
    Ignore the screen. What device will play the animation?
    – hard drive?
    – DVD?
    – other?
  • Kate Koyama
    November 4, 2009 at 7:49 pm
    Hmm… I’m guessing they’ll want a DVD, and also they’ll want to be able to hoop up their laptop to the screen.
    What would be the difference for those 3 devices??
  • Kate Koyama
    November 4, 2009 at 7:55 pm
    Say what would be the output for:
    – playing the video from a laptop that is hooked to the tv screen
    – playing the video from a burned DVD
    – other options???
  • Steve Roberts
    November 4, 2009 at 11:03 pm
    We’re talking about output modules, since your Render Settings would be Best.
    [Kate Koyama] “Say what would be the output for:
    – playing the video from a laptop that is hooked to the tv screen”
    Try Quicktime Photo-JPEG, or H.264.
    “- playing the video from a burned DVD”
    If you’re NTSC (not PAL) your movie must be 720×480 (probably 16:9 widescreen), 23.976 or 29.97 fps. Render from AE to a high-quality codec such as Animation, then compress to MPEG-2 using something like Compressor or a DVD-authoring app. You then have to author the DVD so it plays in a way that suits the presentation. Imagine a non-technical person inserting the DVD into the drive, then what happens?
    “- other options???”
    I’d go with DVD. Don’t forget to test the final product.
  • Kate Koyama
    November 5, 2009 at 2:06 am
    Thanks for the posts!! I have one last question… so if the video is played from a laptop that is hooked up to the HD tv screen… will the composition size matter???
    because today I was making a composition that is 720 by 480 and I rendered as a quick time movie, when I played it (full screen) on my computer monitor (27 inches) the video looked really pixelated…is there anyway to fix this??
  • Steve Roberts
    November 5, 2009 at 3:22 pm
    If it’s playing from a hard drive, and the monitor is 1920×1080 (HD), try making the comp (and render) 1920×1080. Then compress it (try h.264) and play it back from the hard drive. If it stutters, lower the data rate until it plays smoothly.
    The pixellation could be a combination of two things: low quality/data rate, or the enlargement (scaling up) of the video. If it were 720×480 and your desktop were 1920×1080, then it’s being scaled up. You can’t avoid the scaling up with DVD, since it has to be 720×480. However, if you’re playing from the hard drive, try 1920×1080 as I suggested, and the scaling up won’t be a concern.
  • Kate Koyama
    November 5, 2009 at 3:26 pm
    I see… so data….
    I don;t have to import images at 300dpi right???? all my images are 72 dpi RGB (they are 72 dpi but large)
    I
  • Kate Koyama
    November 5, 2009 at 3:35 pm
    OK so from what I’ve been reading the best way is to set my animation in a 720 x 480 ratio (as NTSC) with a pixel ration of ???? (D1/DV NTSC (0.91) or 1.21????
    frame rate of 29.97 frame per second??
    Then when I render the output should be set in as a H.264 Blu ray or MPEG DVD??
    Should the compression still be animation?
    Sorry to be asking so many questions, but I really never went deeper into rendering…
  • Kate Koyama
    November 5, 2009 at 6:20 pm
    what pixel ration does the bluray disc take?
    I just want to make sure the clients will be able to watch a non pixelated movie..
  • Steve Roberts
    November 6, 2009 at 6:29 pm
    So if the client can play a Blu-Ray disc, work and render at 1920×1080 (square pixels), encode to the appropriate codec for Blu-Ray, make the disc and test it.
    If they can’t play a Blu-Ray disc, you have to go with DVD, which is 720×480.
