Activity Forums Apple Final Cut Pro Legacy Output Problems…
  • Output Problems…
    Posted by Creeker on December 18, 2005 at 5:49 pm
    Good day.
    Problem: When I attempt to “edit to tape”, my output video signal in the edit viewer is distorted and comes across as two vertical bands of broken lines and won’t edit. It seems to “print to to tape” OK though. However, I want to do a video insert edit.
    In the timeline – when I’ve closed the viewer (in frustration) – the video and output seem fine. I’ve checked my capture and output settings, to ensure they are the same.
    I haven’t had this in the past. What am I overlooking?
    Cheers,
    Creeker
    Creeker replied 20 years, 9 months ago 3 Members · 4 Replies
  • Bouncing Account needs new email address
    December 18, 2005 at 7:37 pm
    Are you trying to edit with a FireWire control?
    You can only INSERT on a deck with that function (some decks don’t have “insert” mode) and it must be under RS422 control from FCP (not FW).
  • Creeker
    December 18, 2005 at 10:26 pm
    No Via 8 Bit uncompressed tro a sony A500 vis SDI
  • Tom Matthies
    December 18, 2005 at 11:52 pm
    What device/card are you trying to use to send to the Digibeta?
    Tom
  • Creeker
    December 19, 2005 at 2:52 pm
    I’m using the Kona 2 card. Up until the day before yesterday, there was no problem, but now… I quit early yesterday, because I was so frustrated. I’m at it again this morning… When I play the timeline – no problem. When I “print to tape” no problem. It’s when I want to insert edit and use the record canvas to control the deck and set the in and outs, the output is garbled and everything grinds to a halt.
    Hmmmm.
    Creeker
