Activity Forums Boris FX Particle Illusion Output PNGs from PI Render are squashed
  • Output PNGs from PI Render are squashed
    Posted by Marco Rosenberg on August 10, 2012 at 9:49 pm
    Hi there,
    I have a problem with particle Illusion Render:
    I tried to render PNGs of an Effect in Full HD (1080×1920) and the PNGs are squashed in width.
    The strange thing is, if I open them in Windows Picture Viewer, they pop up at the correct aspect ratio for half a second and then squash to square shape.When I import them into After Effects, they are also squashed.
    I tried the same with a custom aspect ratio like 1500×1200, but that also resulted in squashed PNGs.
    Is there any setting or workaround to avoid this or is it a bug?
    Kind regards,
    Marco Rosenberg
    Alan Lorence replied 14 years ago 2 Members · 1 Reply
  • Alan Lorence
    August 11, 2012 at 2:46 am
    If you load the PNGs back into particleIllusion as a background image, is the aspect ratio correct?
    Perhaps there is some aspect ratio info being written incorrectly into the PNG files. Try saving as TGA — does that fix the problem?
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
