Activity › Forums › Apple Final Cut Pro Legacy › output MPEG2 for broadcast problem
  • output MPEG2 for broadcast problem
    Posted by Emmet Reddy on December 22, 2009 at 3:32 pm
    Hi
    I have to deliver an ad to a client as an mpeg-2 clip i cant do it from fcp I have tried using compressor, but I cant get the necessary specificstions can anyone offer advice on how i can get output of specifications below thanks Emmet.
    Video Codec: MPEG-2 422P@ML (4:2:2 Colour space) Program stream
    Video Bitrate: 50 mbps I Frame Only GOP structure
    Resolution: 720×608 (we can accept 720×576)
    Aspect Ratio: 16:9 (14:9 text safe)
    Frame Rate: 25
    Rate Control: Constant Bit Rate (CBR)
    Audio Codec: Mpeg 1 layer 2 (we cannot accept uncompressed PCM audio)
    Audio Bit Rate: 384 kbps
    Audio Sample Rate: 48 kHz
    Field dominance:        1st field / Upper field first.
    Emmet Reddy replied 16 years, 8 months ago 4 Members · 4 Replies
  • Mark Spano
    December 22, 2009 at 4:16 pm
    Sorenson Squeeze (and I believe Telestream Episode Pro) can make the MPEG files your spec requires.
  • Bouke Vahl
    December 22, 2009 at 4:45 pm
    Who is this broadcaster?
    (i suspect you’re in the UK since the 14:9 request)
    50 mbit and NOT uncompressed audio makes totally no sense to me,
    as stereo uncompressed audio is only 1.44 mbit…
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Rafael Amador
    December 22, 2009 at 4:55 pm
    Hi Emment,
    The video requirements correspond to an IMX PAL, however the audio do not match: IMX use PCM.
    Compressor can do the audio, but not the video.
    I don’t think Episode nether Squeeze will be able to do it.
    Mainconcept (https://www.mainconcept.com/site/prosumer-products-4/mpeg-2-20202/features-20220.html) will do it.
    Rafael
    http://www.nagavideo.com
  • Emmet Reddy
    January 7, 2010 at 7:36 am
    sorry i took so long in responding to your kind replies i have been informed that all i have to do is export direct from FCP using IMX PAL (50 Mb/s) settings and thats it email to the digital distribution company who will send ad to what ever tv station you want, no more printing to tape which suites me, well for short projects anyway.
    Cheers Emmet
