Activity Forums Adobe After Effects Output Modules
  • Output Modules
    Posted by Marc Lucas on August 2, 2013 at 10:29 am
    Just getting into setting up Output Modules for group outputs. I usually export out of AE as ProRes 422 & 4444 (for the alpha) when I go into the custom output module settings (not custom panel where you set up your own) the format gives you QT as an option but when you go into custom settings the QT options is QT DV PAL is that the same or different?
    What exactly is the Lossless setting in the Output Module Templates because it says Output info Animation but I would prefer ProRes how do you change to ProRes.
    Marc Lucas replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
