Activity Forums Adobe After Effects Output module won’t let me change render destination
  • Output module won’t let me change render destination
    Posted by Sergio Pol on February 25, 2014 at 12:41 am
    Hello I’m working with AE CC since a couple weeks and haven’t had any problems until today. I send a comp into the render queue but it won’t let me change the destination of the render. I mean, I click on the name of the future file as usual but nothing happens. It seems to be quicktime related since I’ve had somewhat normal results with flv or avi files. I also tried rendering an image sequence and it kind of worked. It rendered the movie as a sequence but it used the last used render destination. I imported that sequence and it wouldn’t let me use quicktime as the format. Any help please?.
    Sergey Krivoruchko replied 7 years ago 5 Members · 6 Replies
  • Sergio Pol
    February 25, 2014 at 1:17 am
    I guess I figured it out. Something weird happened to the project folder and AE and the OS were acting up with it. I can’t even delete the freaking folder. Windows says it doesn’t exist anymore. Luckily I managed to collect the project top a new folder.
  • Roland R. kahlenberg
    February 25, 2014 at 2:24 am
    How does something that doesn’t exist manage to even say something ?
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Tracey Marsh
    October 9, 2014 at 12:02 pm
    Hi Sergio,
    I’m having the same problem out of no-where! Nothing I’ve done in terms of my workstream has changed. It’s driving me MAD! How did you solve the problem please?
    Trace
  • Tracey Marsh
    October 9, 2014 at 1:22 pm
    Not sure if my other post came through but I was having the same problem… an Adobe help chap took over my comp and fixed it for me. Basically, all he did was re-set the AE preferences and that solved the problem.
    Hope that helps!
  • Pablo Sanchez
    June 28, 2015 at 8:48 pm
    I think I found a solution for this!!! I noticed that my folder had a space in the name. I deleted that space and everything started working again.. I was in Maya when I found out about this & it was really frustrating!! Currently running windows 8.1
    Here is a gyazo of what I did:
    https://i.gyazo.com/8d6e39b23cf470b5193bee05585a4739.mp4
  • Sergey Krivoruchko
    September 6, 2019 at 11:48 am
    Hello everyone!
    I have the same problem
    in my case helps delete folder which doesn’t what deleted(in my case it’s last folder which i create through after effect )
    you may delete it by archive and check in arhivator ” delete after archive” and then all works fine
