Activity Forums Adobe After Effects Output Module Failed w/ Element 3d
  • Output Module Failed w/ Element 3d
    Posted by Zachary Dufour on July 7, 2015 at 8:05 pm
    I’m having a reoccurring problem with Rendering/Exporting out an Element 3D v1.6.0 Title animation from CS6. Playback isn’t a problem. However, every time I export a PNG Sequence, Animation, or APR 4444 (basically anything with an Alpha option) the progress freezes up and sometimes I get an Est. Time of 5 hours when it takes 30 seconds to render out on a separate computer with the same specs and software versions. But most of the time whenever I leave it alone to render or “stop” the render it will pop up with the following Error:
    After Effects Error: Rendering terror while writing to file…. An out put module failed. the file may be damaged or corrupted. (-1610153464).
    Version: 10.9.5
    Processor: 2.7 GHz Intel Core i5
    RAM: 8 GB 1600 MHz DDR3
    Graphics: NVIDIA GeForce GT 640M 512MB
    I’ve stripped off every effect and still it will not render out unless its a APR 422 or H264. But I need an alpha channel. Does anyone have any advice?
    Mark Andrews replied 11 years, 2 months ago 2 Members · 3 Replies
  • Mark Andrews
    July 7, 2015 at 10:30 pm
    Do you have Multiprocessing enabled? if so disable that and try it. I’ve had issues with that. In the Memory & Multiprocessing Prefs.
  • Zachary Dufour
    July 8, 2015 at 12:52 am
    What are the idea settings for the Multiprocessing Preferences? It’s already enabled.
  • Mark Andrews
    July 8, 2015 at 1:37 am
    Try turning it off. I have found that it causes problems with some (but not all) ELEMENT renders.
    -m
